Front right brake locks
BRONCOALA
I have a 73 Bronco that locks the right front drum brake. The shoes are all the way backed off. The wheel cyl is about two years old. The brake lines are fairly new. The drums and shoes look good. What is the problem??? It seems that the pressure bleeds off in an hour of no operation and is OK.
Augustus
South Milwaukee, WI.
sounds like a constricted fluid flow.. I had a dented brake line that gave me similar issues. didnt find it until after i pulled the motor,, little bastard hid for 4 weeks while I replaced wheel cylinders checked springs and changed brake fluid several times thinking I had either air in the lines or a frozen cylinder... good luck
B
BRONCOALA
[quote author=Blue_Oval_Boy link=board=5;threadid=16330;start=0#msg124375 date=1050287487]
im kinda confused. does it pull bad to one side when you apply the brakes, or does it completely lock its self up and stay that way for an hour?
[/quote]
It full brake locks. Slowly bleeds off the pressure and unlocks.
