Front right brake lock up?.
Neal1
1976 bronco. Good pads, good rotors. Brakes squeak when starting and front right wheel will lock up briefly. Only happens when first starting. Took to shop, wheel off and saw nothing obvious to explain it. He said likely not calipers as they cause problems after brakes heat up and swell?? Any ideas/help greatly appreciated!
BRONCROB
WISNER LA.
May be a soft brake line going bad or possibly a caliper.Have you ever replaced your rubber lines?If you haven't now would be a good time to.
GDTorx
Bluemont
Along the same thoughts of Steve83.
For some reason I've had more Ford calipers fail out of the box than any other models I've owned.
