right front brake builds pressure
maxwedge5281
concord, nc
I don't know quite how to explain but the brakes work fine for several stops. and, then starts to drag on the passenger side...a lot! I have power disk brakes on all four corners. the front axle is from a 77 model. I can release pressure at the bleeder on that wheel and all is well for several stops and then it starts dragging...a lot...again. it drags so much that you have to find a spot to pull over off the highway. any ideas appreciated or direction to a thread. the front brakes are stock calipers and rotors. the calipers, rotors, and pads are almost new with new rubber lines and new stainless lines to front and rear axles!
Justafordguy
The only thing i ever saw that caused that is a collapsed brake hose at the caliper.
surfer-b
Sounds like the piston is sticking on that caliper and not allowing it to return, I had one do that once before, replaced the caliper and all was well. Like stated above if lines are not kinked, pinched or collapsed I would look at the caliper
68Broncoz
I would have to agree with the above post.
If you don't have new brake lines to the calipers I would start by replacing them as I have had this happen.
The issues is if the pads are dragging it creates heat which expands the brake fluid and creates more drag.
maxwedge5281
maxwedge5281
concord, nc
I did talk to the previous mowner. and, he stated that the braking system was done several years ago and the bronco hardly ever driven....I think I will replace the caliper and drain the brake fluid from the system and see if that solves the problem.
Timmy390
Conway, AR
UGH going through this right now on a non Bronco. Braking system looks new but all 4 caliper sticking. Fluid was brown as brown gets......Same here......system put on then sat for several years....
You can try disconnecting things and seeing if pressure releases starting at the MC. We did this and fluid was flowing at all connection points but the caliper would not retract as in wheel hard to turn. Cracked the bleeder and it still gripping......
Going to pop out a piston and see how much rust is in the calipers. My guess is....LOTS...and it's an aftermarket system so can't just go buy new calipers......very frustration to the new owner.....
Tim
Justafordguy
If cracking the line fitting between the hose and axle doesn't release it but cracking the bleeder does I bet it's the hose at the caliper that's bad.
SHX669
Mine was a sticking piston/caliper - had new SS hoses all around. Replaced the caliper - end of problem
SteveL
Huge chevy guy
Hawthorne ca
Tim
If it has power brakes the piston going into the caliper could be adjusted too deep into the mc causing the fluid to heat up making all 4 get sticky.
As for the original post gotta be a pinched line or sticky caliper heating up.
Timmy390
Conway, AR
My first thought as well as you couldn't spin the wheels at all......and it WAS not adjusted properly. Fixed that (simple enough) and got all 4 wheels to the point you could forcibly spin them but it's still tight as heck. Brakes are clearly dragging.....Took it around the block and the brakes were hot as hell.
Trying to help a guy out....he WAY over paid for a "lipstick on a pig" vintage bowtie. The more we fix the more we find wrong.
Tim
Skytrooper15
Tuscaloosa,Al
I can't add anything to this thread since it appears that everyone has a good suggestion so why not take a minute or two and vote for this web site.It only takes a minute
What kind of car Timmy? And does it have an old proportioning valve on it?
Do all four wheels stick about the same? If you adjusted the booster rod to have a gap before the back of the piston the booster might have a leak in the back chamber.
If there's even a tiny bit of a leak on the back, it thinks you're pushing on the pedal and pushes the diaphragm forward.
Timmy390
Conway, AR
Hey Paul,
It's a Camaro with an unknown disc conversion. Verified the pistons on the front are retracting but not enough. Still has drag. Booster and brake rod are right...Verified that again last night.
Rears well found the E brake was adjusted too tight causing them to drag. Fixed that....then found there was no brake at the rear. Found the MC to original old proportioning valve (that I assume is drum/drum) has the lines to the rear in the wrong place. MC is going to P-valve output vs. input. THEN there is another adjustable P-valve for the rear.
It's a MESS.....Going to rip the whole system off and start over with it.
Fluid in the whole system is like chocolate milk.....
Tim
maxwedge5281
maxwedge5281
concord, nc
well I bought a new caliper and was just sure that would cure my problem as all the other calipers seemd to be working properly....well no luck! same problem as before. I removed the rubber line and it was fine and I checked the hard line from the rubber line to the junction fitting at the front axle vent... all was clear.i cant imagine a problem with the proportioning valve or the master cylinder that would just affect the just right front caliper....any other ideas from the group. ten to 15 brake stops and it starts to hold pressure on the right front brake caliper! im going to put on a new master cylinder tomorrow just because of the discolored brake fluid...I don't think that will help. it is almost as if the caliper does not return back to the home position. I will take the caliper back off and check the slides??? for any burrs on the caliper mount that prevent movement of the caliper. if I am wrong in thinking that the caliper moves please let me know....
Slednut10
Guru? That's funny!
How did you check the rubber line? They collapse internally but look fine on the outside. They will also appear to flow fluid just fine when disconnected.
jckkys
A buddy had the same symptoms on a new van. The dealership couldn't figure it out for months. It turned out to be the rubber lining in the hose to the caliper. The hose liner had separated creating a flap that worked as a one way valve.
On an aside I rub anti seize in the groove that the caliper slides in. It keeps it sliding as designed.
maxwedge5281
maxwedge5281
concord, nc
I did remove the line and it seemed clear but I did not check for the reverse direction that the fluid moves away from the caliper. I ordered a new line this morning....I hope that you are right! and thanks to all who had advice or possible solutions.
No, you're absolutely correct. As you can gather from what was said, the ability to slide is critical. In fact any part of maintenance or replacing brake calipers should always include checking or correcting smoothness, cleanliness, and lubrication of those sliding surfaces and parts.
I use anti-seize as well, like jckkys mentioned. I'm eventually going to buy some specific brake slider silicone lube, but I'm trying to use up an abundance of old anti-seize on anything I can think of! Problem is, a little bit goes a long way.
I'm guessing the brake-specific stuff has very high temperature handling properties and extremely low migration/flow properties. The latter to make sure that any lubricant stays where it's put, and OFF of any friction surfaces.
That's the issue with using just any old brake grease as an anti-squeal solution. Some are just greases and don't have the proper characteristics to get them anywhere near a pad.
But more and more now are listed for both, and so those would be the ones to get.
If there is any doubt as to the smoothness of your sliding surfaces, dress them with a file gently. You're not trying to open up the gap (unless it's already too tight) you're just trying to give it a smooth surface to lube.
Oh, and the equally important aspect of any lube on these surfaces is to keep it from rusting in the long term. Which is why anti-seize and brake grease are better than just regular old bearing grease. They don't wash off as easily.
