CoryOBrien
Anyone know where I can get one of these 90 degree fittings that would work in a Bronco fuel accumulator?
My Bronco is fuel injected, and has a fuel accumulator mounted in the engine bay. Because of where it's mounted, the straight fitting on one side of the accumulator causes a bend in the rubber hose, which is starting to cause a crack. I'd like to replace the straight fitting with a 90 degree fitting like there is on the other side of the accumulator (so both sides would have 90 degree fittings) but I've been struggling to find one. (And I'm not 100% sure what the size of the threaded side of the fitting is, so it makes searching difficult.)
