Fuel Filter Location
kiteoregon
I am plumbing a electric fuel pump, installed on the driver frame rail between aux and main. I also have an electronic selector valve just in front of the pump. Should there be a filter on both lines before the valve, or should there only be one filter up in the engine bay before it enters the carb? I don't know how fragile the selector valve or pump are to water or particulates.
Thanks.
blubuckaroo
Grease Monkey
Ridgefield WA
I'd use just one filter at the carb. Your fuel tank should already have a screen on the pick-up to protect the pump and valve.
More filters won't make the fuel any cleaner.
More filters make troubleshooting more difficult.
More filters restrict the fuel flow.
Factory pickup have a filter sock in the tank. A coarse prefilter before the pump. If running an aftermarket tank it probably doesn't have one of these, just a pickup tube. In that case I like to run a coarse prefilter before the pump to help protect the pump. I also prefer a filter per tank. I have had a filter clog on a trip and made it home on the other tank before.
And always a good filter between the pump and the carb. Pumps can generate trash as they run.
