Fuel Gauge, Help Please!
CopperBronco
Hey all, I've read many many forums on here, and still having fuel gauge problems.
With all wires detached, my new tank/sending unit read at about 40 ohms... and before installed read 10-77 ohms. I should note that my temp and oil pressure gauges already work, but there's a new IVR on the back of the instrument cluster as well. I'm getting about 4.7 volts off back of positive side of fuel gauge, engine temp had about the same... so it seems like IVR is working and doing its job.
When I ground fuel gauge on back of cluster, the gauge pegs to full, I'm told this means gauge is in good working order. Getting more suspicious by the day though as it's one of the few things I haven't replaced, but you can tell fuel gauge has been replaced at one point.
I decided to pull out instrument cluster and jump the wiring straight to the sending unit. I was using 16 gauge primary wire... I used alligator clips between gauge and sending unit connections on main tank and got nothing(I was grounded from the sending unit to the frame as well). So I wired and crimped up a snap terminal for the cluster and a sending unit connector at the tank to make sure I had good connection in wires... still no luck with the fuel gauge. Because I get good Ohm reading off of sending unit when vehicle is off, and the gauge pegs to full when grounded, I thought wiring was surely the problem, and the wiring job is a little spotty in a few areas when I got this Bronco. But I've had no luck with new wiring.
With new wiring jumped from gauge to sending unit directly, when key is off I get a 40 ohms reading, but when I turn the key to On position the Ohms drop to OL on my multi-meter. Which would explain why my gauge is stuck on empty.
I did read you can fry your gauge if you ground for too long... I've pegged it a number of times now, do I need to replace my gauge?
When Ohm testing, should I be getting same Ohm reading at sending unit connectors, & at fuel gauge?
Just to be certain, how do I test and make sure my grounds are good on the frame? Want to make sure I'm not going haywire all over a grounding issue. I have a battery to engine block ground, and battery to frame ground, also added a ground between body and frame near auxiliary tank, and cleaned up ground back at the sending unit. My instrument cluster is also grounded twice to the body/dash.
I've also jumped all cables to an extra sending unit I have, directly from fuel gauge to the unit... it behaved inconsistently for me... when I connected it via alligator clips, I grounded to dash/body and it pegged full, but when grounded with an alligator clip to the top of a ground screw in the frame, I would hook up sending unit, move the float around, and the gauge would stay empty, but maybe hover up just a tad... but not really move...
Any help of advice would be greatly appreciated! I did a ton of research to try and get this right and still getting stumped.
Brent
In addition to what I've mentioned in another message, remember that ANY PART YOU REPLACE BECOMES A NEW SUSPECT, RATHER THAN A CURE.
Meaning that with the state of parts these days, and this is no exaggeration, installing new parts instead of testing the old ones first is no longer a viable way to fix a problem. And ALL new parts should be tested before installing if that's possible. Just to save you at least a little bit of aggravation and frustration at having to test and/or replace a brand new part with another one, when you thought the new one should have worked.
Or better yet in some cases, replacing the new one with the old suspect one.
No more assuming that because it's new, it must be good.
Seems about right, but you really should test any new sending units out of the tank first, to make sure it's going to give at least remotely accurate readings on your own particular vehicle.
Doing it this way allows you to tweak the sending unit to get it to work the gauge properly.
What do you get when reading directly off of the IVR?
Is this a modern PCB type, or a traditional electro/mechanical/thermal points setup?
The 4.7v is low for the IVR, but might be correct at the output of the gauge itself.
Yes. Is this still while mounted to the dash? Or at least still utilizing those two grounds you mentioned?
Jump which wiring? Just the output of the gauge, correct? And were the cluster grounds still intact?
I used alligator clips between gauge and sending unit connections on main tank and got nothing (I was grounded from the sending unit to the frame as well).
Where were you grounding the sending unit? At it's ground connection peg, double checked with the connector to make sure it was the ground side?
In what way spotty? The result you just mentioned is actually indicating both good wiring and a good gauge.
Not necessarily. You don't measure ohms with the power flowing through the conductor. As far as I know (but I'm no ohms expert either!) you can't get a consistent resistance measurement with voltage flowing.
But others can answer that question for you.
Pegging it a number of times for just a few seconds is not going to hurt a good gauge I would not think. If it still tests good i would not replace it. If it fails other tests, then you may need to.
Just don't do it on the off chance it's bad. Test it...
No. Not necessarily. But they will likely be close if the wiring is good. But it depends on where exactly you're putting the probes.
Simply place one of your ohm-meter probes on the ground contact in the connector, and the other one on a clean patch of the frame. Should read zero.
You can scrape the probe around to be certain you're on bare metal, and that would likely be needed as the frame is likely painted/coated, dirty or rusted. Or all of the above.
Might be other ways too, but that's my first go-to.
Seems pretty good. More grounds than Ford ever put on an Early Bronco!
Remember these gauges are using pathetically low amperage, so even a basic simple ground through a small wire is sufficient as long as it's in good shape.
Sounds like you have plenty of grounding kung-fu.
Need to make sure that screw was a good ground. But then again your old sending unit might be bad or failing.
You should have one jumper wire from the output of the gauge to the positive side of the sending unit. Then the "known good" ground to the negative side of the sending unit. Moving the sender through it's range should result in some movement of the needle.
Assuming your cluster is grounded to the dash still that is.
Hopefully others more well read in ohmage lore will correct any misstatements on my part.
EPB72
Pleasant Hill, CA
Paul is correct NO resistance test on a powered/live circuit it can actually damage your test equipment/meter.....
also don;t overlook the connector at the sender is the rubber block push on style? the terminals inside could be a little spread out not allowing good contact with the threaded studs on the sender ,it could be just one of them so you may think it's ok ,,
Loose connection is a great call! All the push on connectors seem to be prone to that, though I think it's less common on the fuel sender than it is perhaps on the two engine related sender connections, but still well worth looking into.
tk1218
Flower Mound
The new aftermarket push on connectors rarely seem to fit correctly. I try to reuse my old 1s if I can
C
CopperBronco
Hey folks all super helpful... so definitely a newbie move to throw parts at the problem I'm learning, so thanks for the reminder there as I learn. I will say this, the fuel gauge is responding exactly the same way it did before I added new parts... so if anything it makes me wonder if I didn't introduce too many new variables (crossed fingers). I did try to diagnose before putting on new parts... I'll add the tank was replaced because it was really beat up and collapsing, and I didn't want a poly tank. All the testing I started out with happened both before, and after new parts. So this is all round two with new parts and getting exact same result despite part changes. I have all the old parts as well to revert to to remove any new part variables as well!
Regardless the main tank needed replacing and it made sense to put in new sending unit at the time. The sending unit was tested before it was installed, it read 10-77 ohms... so not too bad, I'm told mfg numbers are 10-73 ohms... I also have been driving it around burning gas and testing ohms on new sending unit and it's moving up like it should, it was 50 this morning and after a drive it moved to 60... so I think float/unit is working...
Paul to your questions:
I will go test IVR again, I can't remember number, but I wanted to say around 5volts as well when I originally tested. My IVR is the newer kind with green color on it, not the original OEM brown/tan one.
Random fact I learned from a Bronco restoration gauge expert today, the engine temp sending unit gauge and fuel gauge are actually the same gauge with same ohm rating... so in theory when diagnosing gauge you can hook wires up to the engine temp gauge to test sending unit as well and see if it reads... I was also told you can't trust the new fuel gauge replacements, but should source an OEM one and fix it up, one made in Michigan.
As for PCR vs. electro-mechanical... forgive my newness but I don't understand the terms fully and didn't Google it yet :) ... I'm pretty sure it's electro mechanical in that I have two posts coming off the back of the gauge, the positive is connected to IVR / auxiliary switches, as 3 aux gauges are kind of wired together it looks like. My gauge is also looks stock, doesn't have any digital tech in it. I'm going to pull cluster out tonight, so I'll take photos and post.
Paul, yes my cluster has two ground wires on it that go from screws of cluster to the dash, so whether cluster is installed in dash, or removed from dash it's grounded. Either previous owner had a gremlin grounding issue and added them, or they did it so you could pull out cluster and test without pulling out entire dash.
When I jumped wires, I mean I jumped the fuel tank selector switch and all existing wiring, my goal was to test if my wiring was bad by bypassing all the old wiring with new wiring. So my hookup was as follows:
Cluster pulled out from dash, but still grounded via 2 ground wires from cluster to dash. With IVR input cable still hooked up to fuel gauge, I squeezed alligator clip onto the other terminal that normally hooks to fuel tank selector switch, and I ran that test lead wire straight to positive/power side of a sending unit, both my old unit in my hand, and new one in the gas tank and ran separate tests, an A/B test if you will. With each sending unit I grounded from sending unit to the frame. The advantage to the old sending unit, which I held in my hand, I could move the float around and test to see if readings changed (which they didn't really, only slight movement in gauge). I also ohm tested that sending unit and got 10-77 ohms. Neither test changed my fuel gauge measurement. I can just consistently short the gauge and it pegs full.
By "spotty" wiring I mean I found auxiliary tank wiring not even connected to the dash, just floating near my driver firewall, wiring is all loomed and taped together and zip-tied to avoid too much movement, but connectors are not all insulated, heat shrink wrapped, etc... so probably could have been done better, that's what I mean by spotty, but overall most everything works. It's a good job, but not a GREAT job if you get my drift. I'm a type-A perfectionist if you can't tell. The Bronco is going to recondition me into a type-B person :)
Let's confirm sending unit ground side since you asked. I'm assuming that the ground side is the metal peg that goes into sending unit, and on the other side you just see the threaded screw, and the positive side that wires up to front of Bronco from fuel tank is the threaded screw/connector that has a wire coming out on the other side. Is that correct? Just to confirm the basics here... terrible design if end up telling me it's the other way around!
Where should I put my probes to ohm test on the back of the instrument cluster fuel gauge? I was assuming I need all wiring hooked up, and squeeze test leads from multi-meter to make contact with base of connectors, maybe loosen the connections a 1/16" or 1/8" to fit those test leads in, but keep connectors still tight.
Thanks for the concrete tip on testing grounds I'll look at my grounding kung-fu and make sure it's all working.
About to go pull cluster, I'll get photos and run a few more tests. I am hearing that it's possible gauges themselves need cleaning & restoration, and that IVR can be tuned to make sure you're getting right readings.
I'll throw in one other possible diagnosis issue, my engine temp sensor wasn't working at all when I got the Bronco, I put in a new sending unit into my 302 V8 block, and I get a reading now, but I know it's not right. At idle after running for a while it says 140 degrees, but I researched this and sounds like 302's run around 180-200, so I have an infrared laser temp gun coming to find out what it's actually running. So temp sending unit is running low as well. Which makes me wonder about the IVR...
C
CopperBronco
Hi All, so pulled out cluster...
Here are some photos of the IVR, and back of cluster... you can see fuel gauge was replaced at some point.
I tested the IVR on the top connector you see in photo where metal was exposed with key turned ton, on both sides of it I got reading of 5.7 volts from IVR, at fuel & temp sending unit gauges I get 4.8 volts.
I should also add oil pressure gauge seems to work, once warmed up and at idle sits around 40, at first it does shoot up to 70 as engine warms up, I need to do oil change, wondering if thicker oil is causing this, but it settles down to normal.
I also checked ohms at back of tank, fuel selector switch, and fuel gauge with key turned to off.
Tank sending unit read 60 ohms – grounded to frame while doing this
Tank wire to fuel selector switch reads 60 ohms – ground to frame while doing this
Fuel selector switch wire at switch to fuel gauge reads 198 ohms – grounded at frame & dash same reading
Fuel gauge connector at fuel gauge reads 198 ohms – grounded at frame & dash same reading
So there's way too much resistance going on here..... which explains it trying to stay at empty... but I bypassed fuel tank selector switch yesterday and didn't get a different result... so stumped on that one a little. I did clean the contacts of the fuel tank selector switch with metal wire brush and electrical cleaner yesterday as well. I need to bypass the switch again and measure resistance again. Run too many tests and can't recall what that was. Need to write all down.
Hit me up with any ideas if you folks have any. I'm thinking about sending gauge out to Classy Gauges to be restored anyways since my speedometer wobbles a little. They weren't positive of issues I was having, but said they could at least restore instrument cluster to be all factory settings and guarantee the cluster itself isn't the source of the issue.
Someone mentioned push on pigtails aren't good for sending units, any tips on how to fix that? What type of connector should I buy, a snap terminal / female socket receptor? It had one of those old school ones on before, but it was hard to find replacement, all the new ones I ordered were too small and didn't fit right.
Thanks all! Any further ideas much appreciated on how to solve. At some point it's time to just get a Jerry can and move on... but would love to have working gauges since this is a daily driver.
C
CopperBronco
One more thing to add, I measured resistance with my multi-meter on engine temp sending unit, my multimeter ground touching ground of battery while key was off, and positive lead touching the top of the sending unit out of engine block and got a reading of 186 ohms... so lots of resistance in my two gauges that are not reading / reading low... so diagnostically that makes sense, if 73 ohms is empty / non reading on gauge, I have way too much, but no idea how you go about fixing that... would much appreciate any help.
You have to figure out if it's the sending unit itself (the "fix" in this case is to replace it) or the wiring.
If you ground the sending unit wire and turn the key on, the needle should peg to full and beyond.
If it does not, then there is a fault between the connector and the gauge.
If it does, then the fault is with the sending unit OR the connection to the wire.
And I don't believe that you used the correct procedure for checking. If the unit is out of the engine just sitting there, the one probe should be to the threads and the other to the stem/tip. You're reading ohms "through" the unit, not to the battery.
If it's threaded into the intake manifold still, then you measure between the stem and the body of the unit still, but you can also check it's connection to the engine ground by measuring ohms between the stem and the engine.
Hopefully someone will chime in and correct any of that if I'm wrong about the testing procedure.
Regarding oil pressure, that's exactly the pressure Ford specified in the books back in the day. Seeing 70psi cold is fine, and 40psi hot is also fine and expected. But yes, oil viscosity makes a difference.
In general terms, there are lots of different oil weights that are compatible with our engines. I believe a good 10w/40 is the all-around go-to weight for us, but I ran 20w/50 in mine for 40 years and it retained it's good pressure readings the whole time.
I think I'm running 10w/30 in my Explorer engine (or is it 40?) and now realize that 20w/50 is thicker than is ultimately desired, but that heavier weight served me well in the clone wars... uh, I mean in the hot summer weather that I put the most use on the engine in. The hardest non-commute use was always in the 85-110 degree range outside. Never had a rattle upon startup on a cold morning, and never showed any extra signs of wear and tear that I would not expect.
And that's with freeway travel in the 3,000rpm and up range over a long period of time.
By all means do a search for discussions of oil weight to see what most are running, but I don't think you could go wrong with a 10w/40.
A little thinner if you live in a cold climate.
And speaking of which... Where part of the world are you in by the way?
C
CopperBronco
Hi Paul,
I'm in NW Oregon, so not far from you. The engine sending unit was threaded in the engine block when I measured, so I re-measured from top of sending unit with wires removed with my test lead, and put ground lead down on engine ground and still got measure of 182 ohms. I'll short it soon and test that as well. I suspect it will peg full like my fuel gauge does... I need to do some research into what causes such high resistance. Just corrosion? or other factors?
I hope to have more time this weekend to test again and get back to you. Hopefully I can resolve all this. Thanks again for all the help! Can't thank you enough for teaching me how to go about this. Definitely making some rookie mistakes, but that's how you learn, right?
C
CopperBronco
Also, any guidance on best place to buy electrical parts for broncos? Didn't know if there are specialty wiring places that carry any speciality parts/pieces that might be needed sometimes in the future.
Oleguy 74
on the home page.on the left side is a page called community.click on that.when other menues come up click on electrcal.then click on wiring diagrams.then you will see a menue called seabiscuit.then click on it.click on your bronco year.now you can see how your stock wiring goes.rember all the electrical requires two things,you need battery & ground to work.loose one or the other nothing works.the rest is testing with volt/ohmmeter.rember as you have seen ohms cant be tested with power on.if you would like,call me at 760-608-3907 mike.
C
CopperBronco
Hey guys, wanted to follow up on what was actually wrong here. So my fuel gauge was stuck on empty no matter what I tried. I tested sending unit with ohm meter and it tested right, 10-73 ohms, I shorted the wiring at the main stock tank and gauge pegged to full, supposedly meaning the gauge is good. I also bypassed all existing wiring by hooking up new wires from sender straight to the back of the fuel gauge bypassing all old wiring & fuel selector switch. This moved the needle on my fuel gauge just barely.
So the fix was to put an original IVR (the brown ones, not the green ones back sold by most part suppliers), you want the ones made in Michigan originally. Kevin at classy gauges in Salt Lake City helped me with that one. Then also had all gauges properly restored... the fuel gauge itself was out of range for ohm metering, even though it pegged full when shorted. So don't always trust the shorting diagnostic trick was the lesson here.
FYI, the oil pressure, water temp, & fuel gauges are all 10-73 ohms, so you can actually cross test with them. The only main difference being is that the fuel gauge must ground to the frame. The other two ground to the dash/body.
All my grounding kung fu was working and I didn't have a gremlin, so that was good. All in all a giant pain, but now both my main and auxiliary fuel tank gauges work. Just thought I'd follow up as it sounds like fuel gauges and Broncos can be difficult to fix.
Also, this wasn't my issue, but if you short your gauges for too long or too often this will also cause the ohm resistance range to get out of whack is my understanding. So be careful doing that too much. Don't let the gauge peg all the way to full if you're shorting them to test.
Also, as Paul I believe said, the IVR itself has an adjuster on it as well, it sounds like voltage coming off of the IVR should be 5-7 volts or so, I think 5 is OEM recommendation in my shop manual. But sounds like people get it working inside those ranges.
Overall, now all my gauges work and updated with a new voltmeter since I have an upgraded alternator. Nice to not be flying blind down the road while driving.
C
CopperBronco
One more thing as well, my oil pressure read perfect stock OEM, but I also tested that with a mechanical pressure gauge, turns out since my compression on each cylinder is like 190-205 for each cylinder, which is really good I'm told, is due engine being remanufactured not that long ago. So with all the gauges fixed my oil pressure reads steady at 70 hot or cold now, and I'm told that's because the parts are newer and it's holding pressure at temperature, but eventually with use it will wear down and start to lower down. My mechanical gauge matched the dash gauge now, so it's accurate. Did some other pressure tests and all seemed up to par. But I'm new at this. Call me out on anything.
Hey, great report! Both for having a great result and for being so thorough too. That gives us a lot of information to go with. And you're right about full grounding test not being a come pleat Lee accurate test. It just lets you know that the gauge is doing some thing and the needle not stuck. Unfortunately it doesn't tell us everything as we just found out with yours. Glad you stated that.
And yes, it's wonderful to not have the guessing game going on when you're driving!
Just so we have all the information, what viscosity oil are you using in the engine? It doesn't make as big a difference with factory gauges, but oil viscosity can still make at least a small difference in overall pressure. Especially with an older worn engine.
One of these days I'll have to go through the original gauges from my 68. Seems the original one bottoms out at 20 pounds even with the power removed. Never goes to zero.
Always one more thing to fiddle with.
