OK, well I was checking why aux fan and AC not working. THere is power where the relays are, or should I say "was" power at the relays. I am talking about switched 12v that comes on when ignition switch turned on.
I pulled relays and was jumper wiring around to see if the fan worked, it does, and to see if ac clutch engaged, it does, and also the blower fan on the inside. It all works. But in the process of doing this, I lost the switched on power at the relays and havent found where to fix this issue yet. I obviously overloaded that circuit while messing around and blew a fuse or something. Everything (fuses) that I can find checks OK. I just dont know where else to look but im reseaching !
Im guessing that the relays are bad for one thing, the other problem is I dont have 12v from the battery where the AC relay plugs in. I dont know enough about the system but im learning !
