Hardpivot
- May 13, 2013
- 24
Hey Everybody,
I recently converted my Bronco to fuel injection. I went with a stock 5.0L HO intake and a painless harness bolted to a 351W. After a ton of problems and vacuum leaks its running ok, but I am still having some issues.
The biggest one seems to be sensitivity to moisture. On really wet days the truck will run fine until something in the system gets wet, then it will want to die. The only way to keep it running is to floor the pedal in first or second gear and even then im only cranking out 2500 rpms and it struggles and shutters the whole time. What in the system is sensitive to water and does this sound familiar to anyone?
Another piece of the puzzle is that in order to chip the ECU, a hole had to be cut in the back. Now the chip protrudes from the opening in the back of the computer with no real protection and its mounted near the floorboards in the cab that get fairly wet in storms. When it was running rough in the storm, a red light was flashing like crazy on the chip and the ECU was making a bunch of clicking noises. Could it be that the computer or chip got wet and malfunctioned?
When I ran a check for codes, in engine of I got two: #78-Time Delay Relay Fault, and #15-EEC ROM Test Failed/Power Interruption to EEC. I don't know what either of these mean, but are they related and should I be worried about them?
Also, does anyone have any good recommendations for better water-proofing my system and computer?
Sam
Sam
