Fuel Leak Holley Sniper
AJBronco
I’ve got a 69 Bronco with a 302 and Holly Sniper EFI. I started it up today, and it was idling rough. After letting it idle for a bit I noticed a fuel leak from the engine compartment. My fuel filter is mounted to the firewall and the was coming out of the fuel line connection on the engine side of the filter. Any ideas what is causing this?
A
AJBronco
Already checked that. Everything is tight. Fuel line is in good shape, too.
There are a thousand variations of fuel filters and a hundred variations of fuel lines. You are dealing with aftermarket parts. There is no telling what you have. Just guessing. We can only guess so much. At this point we need pictures as the basic guessing hasn't worked and words are not adequately describing the situation.
