A newer appr. 3/8ths blk plastic fuel line runs from the rear tank to the front of two holes on the right side of the manual fuel switch. The 3/8ths plastic line then comes out the switches bottom side and goes to the fuel pump. (A appr. 1/4" line also comes off the rear tank to the rear hole on the right side of the fuel switch) QUESTION: Is the old metal line coming off the rear of the fuel switch and going to the fuel pump area(plugged and not attached) likely an old abandoned fuel line, or a vent line that should be attached somewhere? Thanks for your help! (stock 1973 w/302, stock manual pump). Bought a month ago-no history. JB
