I will be running a 3/8" stainless tubing as a supply line, does anyone see a problem if I ran 3/8" for a return line in my EFI setup? I have the EFI tank with built in pump. I've read where the return should be 5/16"
5/16" is the minimum return line size you should run...3/8 should be fine although you'll probably need to adapt where you connect to the EFI tank as the nipple will probably be for 5/16" hose.
