BoureeOne
This one has me scratching my head. This is my low pressure line feeding my FiTech Fuel Command Center 2. It is being fed by a Carter Electric Fuel Pump. Carter should be putting out about 5 psi. The gauge is a non-liquid filled gauge that goes up to 15 psi. I have 58 psi from the FCC 2 to the FiTech 600. The low pressure gauge always reads zero. I have removed the gauge and quickly turned on the low pressure pump, and fuel shoots out the hole under pressure. I have rotated the gauge facing downward to see if somehow air trapped in the gauge was not letting it read, still at zero. I also have tried two liquid filled gauges, all read zero. The engine runs perfect. I feel like I am somehow missing something simple here. The gauge is mounted on an adapter that is 6an male and female.
