Fuel Pump Question
70 sport WA
70 sport WA
ntsqd
heratic car camper
Upper SoKA
Think about what is happening in the fuel supply system. With a mechanical pump the line from the pump all the way back to the tank is under a partial vacuum. It works fine until the EPA mandates a "gasoline" that has a lower temperature collective boiling point. Now that vacuum causes the fuel near any hot spot in the long supply line to boil. Presto, vapor lock. I forget the exact numbers, but some time ago I calculated the boiling temperature for some of the components in gasoline when under a partial vacuum, and it was quite easy for that temp to be as low as 90° Keep in mind that is the temperature of the fuel, not the ambient temp.
With an electric pump the fuel between the pump and the engine is under pressure, thereby raising the fuel's boiling point and making it harder for the fuel to boil and cause vapor lock. With the pump in the tank or close to it the length of supply plumbing is much shorter, and at least partially submerged in fuel.
For years people did all sorts of janky things, some effective, some flat out dangerous trying to head off fuel boiling AKA vapor lock when the simplest solution is to pressurize the fuel and raise it's boiling point high enough that it won't boil. Some very late carb'd vehicles use a by-passing fuel filter. Too little, too late, but they did mostly work even if the only line pressurized is from the pump to the filter.
You probably remember, even some Broncos had fuel return systems built in from the factory. Very few unfortunately, as it seems many more could have benefited from this little feature.
I think in the mid to late 70s, Jeep put a bypassing return filter on the six cylinder engines. Maybe even the V8.
Came that way through the mid 80s if I remember. Maybe even later, because they kept carburetors longer than most manufacturers.
First time I remember seeing a return line in a fuel filter was in the turbo charged Corvair’s of the mid 60s.
Only reason I didn’t try using one on the Broncos was because of the smaller fittings.
Wish I had known about the Jeep one a long time ago! I’d have tried to figure out a way to plumb one into my 71.
Even though I rarely had any issues with it, I thought it would possibly be a good way to avoid them.
ntsqd
heratic car camper
Upper SoKA
Had a '78 Cherokee Chief with a 360 that had that by-passing filter on it. Really liked that truck, it was too bad that it was so rusty.
In theory a guy could build a by-passing system using one of those filters. I wouldn't do it because they are likely getting harder to find and there's a better way. Use an EFI pump and a by-passing regulator. That gets you currently common parts and fuel under a higher pressure than the filter could deal with.
The flow ratings on the pump are not what they are going to flow. Only the potential to be able to flow that much. Restrictions, filters, needle and seat in the carb are all limiting factors. With enough restriction, there will be 0 GPH flow. Going to a higher flow pump won't more more fuel if the restrictions holding the old one back don't change. The only way a bigger pump will actually more move fuel is if all the restrictions are not the limiting factor and the pump capacity isn't good enough.
I've run a 72 GPH pump at sustained full throttle on a boat on an engine that can make ~250 HP as long as there is fuel in the tank.
There is math that can show what flow is needed for a given HP level.
