Fuel pumps ?
hartbronco
Powell River B.C Can
You Guys that are running EFI 351W, What fuel pumps are you running ? I'm getting ready to start my EFI swap. So I was looking on the board and I didn't find much ! Can You give some insite to this? what is the best pump and why ? thanks for your input .
ransil
if you want to run 2 Low pressure Carter P4070 use that to feed a Hight pressure E2000 or equivalent.
why?? it works..
High pressure look up 88 F250 5.8L you want the external one..use rock auto or o'rileys web site then click see what else it fits to get your junkin list if shopping that way.
I have installed high pressure externals only near the tank and they work Ok, no issues on the 2 I did, the 2 I own have a low pressure feeding a high pressure..why? its cheaper
next one I do will have a high pressure intank...just waiting on my gas tank to get cut out to prototype it..
Ron Gildersleev
DFW
low into high
I have the carter/low running into a msd/high w/o any problems. Worked flawlessly to the top of Mt. Antero, to name just one. Low press. is on the rear bumper with high pressure on the d/s fender. Tried using an accumulator with disasterous results. Both pumps energized by the same relay. Summit has a high pressure on sale for around $75 I believe. Looks like the msd.
hartbronco
hartbronco
I like the Idea of the external pumps because I could change it out on the trail if I needed to, I also like the idea of the pump in the tank ( for safty ) seems like a better spot to Me . So what pumps are you Guys useing in the tanks ? and do you use a HP and a LP pump for the in tank setup ?
Darren
ransil
Darren
in tank they should last longer as they stay cooler.
if using an intank HP should be all you need.
i have no got one yet but the pump I was planning on is a intank 1992 mustang pump
hartbronco
hartbronco
I picked up 3 pumps Yesterday all are Carters P74028 High Pres.( this one is a frame mount).... P74067 Low Pres.(this is a in tank pump)..... and the P4070 Low Pres.( I don`t like this one !!! it seams to big and the mount doesn`t look the best IMO (every one says that they are loud to) The hot rod Guys I know tend to use this pump to feed the carbs and are telling Me that they are a loud pump . So I think that I`m going to try the P74067 in the tank and the P74028 on the frame . I`m not 100% on this yet so thats why I grabed the P4070 as well . What do You Guys think .
hartbronco
hartbronco
my 2 P4070 are quiet, the high pressure pumps get noisy..
Do you have a pic of were You mounted it ? Maybe the Hot Rod Guys are mounting it to close to the Drivers seat and thats why they can here it ? It would have to be pretty loud for me to here it when my bronco is running !!!
