ntsqd
heratic car camper
Boiling fuel is vapor lock. Can achieve boiling fuel at sea level if the temperature is high enough, and it doesn't need to be a record setting heat wave to do it. What I recall from looking into that 10-ish years ago or so was that the light ends of fuel will start to boil in the mid 90's at sea level pressure. As the atmospheric pressure drops with an increase in altitude the boiling point temperature goes even lower.
Mechanical pumps put the whole supply line under a slight vacuum. That lowers the boiling point temperature. Going up in altitude lowers the ambient pressure. I suspect that mechanical pumps create a fixed vacuum relative to ambient pressure. Which means that at higher altitude the pressure on the fuel in the supply line is even lower. I'm working backwards from vapor-lock occurs easier at altitude than at sea level to deduce how a mechanical pump behaves.
That could be wrong, but it fits what I know about when and where vapor lock occurs.
Pumps at the tank or near it are great because they put the supply line between it and the engine under pressure, thereby raising the boiling point temperature. Electric pumps aren't immune to vapor-lock. With an inline pump the section of the supply plumbing between it and the tank is under a vacuum too. This is one of the better reasons for an in-tank fuel pump.
