mkaenel
Hello,
My EB tends to feel like it is running out of fuel while driving. It sputters and stalls out sometimes even driving on flat surfaces.
What I have done to fix the problem.
1. I had the carb rebuilt and tuned on the truck. Also made sure there is no vacuum leaks.
2. I went through both of the fuel filters (one by the tank and one by the carb) and cleaned and/or replaced the filters.
3. Plenty of gas in the tank.
When the electric pump is on it shows about 3.0 to 3.5 psi at the fuel pressure regulator (right next to the carb). Seems low and should be at 5-6 psi.
Can a mechanical fuel go bad and quit working properly?
My next step will be to r and r both the mechanical and electric fuel pump.
Any thoughts on what else to look at? It has a mildly built 302 and an Edelbrock 4 barrel carb.
Thanks for the help.
Matt
Matt
