Fuel switch/gauge/pump wiring help
GraficO
Albuquerque, NM
OK... is this drawing correct if I want to by-pass using the centech harness wiring for the fuel senders but add the following?:
- use the stock gauge
- use an electronic fuel switch instead of the manual valve
- use the stock fuel switch
- run either the AUX pump or the MAIN PUMP using the dash fuel switch
- get MAIN or AUX fuel sender signal depending on which way the switch is thrown
Just want to make sure I'm not seeing purple monkeys
bax
Old Member
I feel they are correct. But Viperwolf is the grand master
red hot71
kent wash.
IF you are using a carb you only need one pump hook it to the single outlet of your switched valve run the pump off a relay switched off the ing.,on, side,run a new wire for the switching valve,run each tank to its appropit side of switching valve,keep both centech tank wires use them for each sending unit only,if you want a simply safty switch for electric fuel pumps use a 5-6psi.switched on hobbs preasure switch tapped into your engine oil presure,that way the pump only works when the engine is runing.Fewer parts.
Viperwolf1
electron whisperer
Looks ok to me also. Make sure the IVR is grounded.
