Fuel tanks.
Pa PITT
Stephenville TEXAS
... OK You already know how RedNeck I am. So this question shouldn't surprise yourself. .. What would be wrong with a 2nd FUEL TANK.. ''Remember I run Diesel Fuel'' Not as Flammable as gas .. But there is a 18 or 20 gallon Tank that chemicals come in. . It has an upright stance with a D handle on top. It also has a Drum Bung & a 3/4 pipe plug in the top. I keep thinking what would be wrong .. Since I have a Half Cab. Mounting it in a cup mount on the floor & a circle strap too my Head/Ake rack. My Head Ake Rack is about 2 inch Square tube .. ...
... I'm thinking take the 3/4 pipe fitting and CNC a fitting to drop a intake line into the tank. Place an Electric P4070 ON THE 2 inch square tube of the head Ake Rack. & run the fuel line down to the line to the motor...
... These Plastic 20 gallon buckets are about 1/4 thick. If you used the White one you should be able to see your fuel level. I've seen White Black & Blue.
.. Looks to me like I'd never run short of fuel again.
.... So What's wrong with my Ideal. & Remember I use my Bronco on the farm not town. My Bronco is almost a service truck. & headed that way If I can get my OnBoard welder going. & My On Board air Compressor.
broncnaz
lol that would work but wont help your rusty tank any. plus where you going to put the welder and compressor? Wait I can see it now never mind:-X
moses_m
Why not just a install a diesel tank in your bed and gravity feed it to your filler hose or your fuel tank selector valve? Thats the way I have my diesel pickup. I have a L shape tank with a tool box on top. They can get pricey but there are several on craigslist.
Rustytruck
Your electric pump isn't going to like pulling fuel up almost 3 feet. If you mount the tank horizontal You can cut some of that head load but you would have to put an elbow fitting in the 2 inch bung with a cap and a vent system.
deltarat
Drew,Ms
I don't see any reason that you couldn't make a saddle with straps, lay it down and run off the lower bung and use the big bung for vent and filling. It would be gravity flow to your fuel pump.
I have used tanks like that to build small spray rigs all the time. Roundup drums last a long time and hold up to abrasions very well.
Pa PITT
Pa PITT
Stephenville TEXAS
... I got one of these drums today.. ''LOVE MY JOB.'' I go everywhere ...I only gave 10.Bucks for it. Laying on it's side would be sweet But I BET IT'LL LEAK on it side. . Ok if you think the P4070 won't lift the fuel up 3 ft then how about the . Stock 2000 24valve lift pump that normally bolts to the side of the block. I've got several of those used ......
... That is the supply pump I'm running on my 4BT.
.... And compressor is up-right same size it sets on one side and tank drum set on other side. .. Welder is planned to be a Weld-N-ator under the hood..
People under rate what the P4070 will pull. Remember that there will be a siphon effect going on as well. Once primed the pump will be gravity fed (so long as it is below tank). Diesel has a much higher boiling point than gas, it can be pulled a lot harder and not vapor lock. How well can a P4070 pull? I have mounted one next to the master cylinder in Phoenix. It would pull fuel from the rear tank, through the selector valve, through a filter, all while mounted high in an engine compartment. And this was pulling gasoline. And worried about pulling fuel 3 feet? If you did a top pull of 3 feet, then loop down 3½ feet, there would be a net -½ foot of lift. If you unhook the fuel line at the pump you will spill fuel because it is siphoning out. All you need to worry about is that initial prime.
Pa PITT
Pa PITT
Stephenville TEXAS
..Damn these Bronco GURU'S are sharp. Bowsher your correct .. I kept thinking last night it was not correct to mount that pump on the Head Ake Rack . But I could Not come up with the real reason. Other than it would have more drag.
... I was wanting it to be up on top so I could Swap And Fill other items or roll the COAL into my Stock tank .. I was also thinking of using it as a nurse tank. Just to resupply my stock tank...
... Oh the Guy I bought that tank from said it's ONLY A 15 gallon tank. So That is a big help but not 20+ as I was thinking those tanks were.
broncnaz
Im pretty sure the stock 24v lift pump is a carter might not be the 4070 but its the same basic pump. But I agree the carter wont have any issues feeding your engine
Pa PITT
Pa PITT
Stephenville TEXAS
.. I don't think it will either .. Today I stpped at about 4 HARDWARE STORES ... Man Brass fitting have gone up in price.
.. A 3/4 bushing was about $9.00 ..& i NEED ABOUT 4 MORE FITTINGS ..
