Where did you end up getting them Steve?
Was it far enough back that you just got the Warn product? Or did you have to go to a custom type driveline fab shop that sells that kind of thing?
Pretty sure the outer hub diameter was Dana 60 stuff, but also remember the axle spline count being something unusual. Such that just a pair of Dana 60 lockouts would not work.
And then they did that little set-screw "fix" when people's hubs were self-unlocking for some reason. At least I think that's what was done at one point with the Warn kits.
There were two types of hubs available for the 9" - it looks like from the pic posted that it had the Dana 44 style hub. Same outer spline count but the inner was different (30 spline maybe?) such that our front and rear hubs didn't interchange. The larger style used Dana 60 style hubs. The set-screw setup was in the 44 hubs from the beginning.
Steve Sampson (longtime EB owner and EBR founder) is still using the Warn rear floater setup on his truck and has been more than patient with trying to keep them going. I think his latest solution is using a set of Yukon hubs with the proper spline counts.
Todd Z.
Was it far enough back that you just got the Warn product? Or did you have to go to a custom type driveline fab shop remember the axle spline count being something unusual. Such that just a pair of Dana 60 lockouts would not work.
I bought em from a specialty shop called wh. Also a bronco guy that was working at 4wp years ago gave me a warn spec for axle replacement parts. When I looked at the ff outer spline count it matched a 60. It was quite a bit cheaper to go with the flanges so I quit investigating the hubs.
