Full width 78-79 Bronco rear diff swap
dgold_881
I'm finally getting around to welding the spring perches on my full width axle swap but wanted to make sure the Pinion angle is correct before I welded them. I attached the angle meter photos. For info Its a 5 1/2" wild horses lift with 78 Bronco full width axle swap. What should the degree be so theres no issue with bind or wobble?
Thanks for any help.
76Broncofromhell
Bronco Totalitarian
Grass Valley, CA
Consensus is on a double-cardan CV you want the lower joint to be within 0-5* of the driveshaft at static height.
It looks like your axle is at about 16* and your driveshaft is at about 26* - which is too much angle. I would tilt the pinion up a few degrees and look at it again.
Remember the pinion is going to nose up under power slightly due to the nature of leaf springs, which is why you can have a bit of variance on the pinion being down angle from the driveshaft.
Directly parallel is not optimal because it doesn't allow the needle bearings to spin and can potentially flat spot needle bearings and u-joint trunions. That's in theory of course - in practice it's pretty much impossible on a leaf sprung rig since there is a lot of inherent movement in the suspension through travel, axle wrap and imperfect suspension angles.
frenchy
Hi guys,I have a ? on this subject. 76bfh where would you place the angle meter to see if you have the 2* your talking about. I will be doing this someday and would like the info.
dgold881 I would like to see some pics of your front end. Is that the full width already installed? You can pm them to me if you like.
frenchy
dgold_881
dgold_881
I will try that in the morning.
broncnaz
You may want to add some weight in the rear if you dont have stuff like gas tanks rear bumper or a cage ect installed yet. As its best to set the angle when at ride height. The closer you can get to 1 -1 1/2 degrees differance on the pinion angle vs the shaft angle the better.
dgold_881
dgold_881
I can throw on the Proto Fab rear bumper on and put the front bumper in the rear to add simulated weight. The hard top is on as well.
broncnaz
Yeah whatever you think will be close to what you intend on running. plus the rear may settle a little after some trail time. The front bumper in the rear may be close to what a tank of gas would be. May want to throw a spare tire and a cooler of beer back there to. then again the beer cooler might not stay full for long. lol
76Broncofromhell
Bronco Totalitarian
Grass Valley, CA
frenchy
Put the angle finder on the driveshaft tube and then on the pinion housing or yoke.
Solid advice. I usually stack whatever rig I'm doing with some sort of ballast to get the measurement right.
dgold_881
dgold_881
Ok right now I have the lower yoke at 25 degrees and the drive shaft at 25 degrees should I put the yoke at 22 degrees to anticipate the up tork so that will be inline during acceleration? Or should the yoke be at 20 degrees?
dgold_881
dgold_881
I finished the front end awhile back. I bought new heavy duty spring buckets and the extended coil spring towers from Duffs so that the coil wouldn't have to much of a bow in it. I cut off the old towers and welded them on. I attached some photos of the front end. Its a little rusty but will look great after I get it to media blast.
frenchy
