Full width dana 44 questions
yakelys69
According to many threads I've read the minimum suspension lift for a high pinion Dana 44 is 3.5". I've also seen a number of post of owners wanting to keep the suspension lift around 2" - 2.5" as I would without loosing up travel or at least not to much. I believe the clearance issues come into play on the following.
  • Drive Shaft to exhaust (no long tube and possible issues with shorty headers)
  • pumpkin to frame ? ( not sure on this one )
  • pumpkin to oil pan ? ( not sure on this one )
So some clarification on that would be great. Also would a low pinion dana 44 have the same or different clearance issues?
I would love to just pick up some axles and play with it but can't afford to do that, hope some experienced members chime in.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
I've been running a high pinion D44 since 2006. When I first installed it, I still had the el cheapo 2" lift that was on my Bronco when I bought it. I was and still am running shorty headers from Wildhorses and true dual exhaust.
With just the 2" lift, I would regularly bash the front driveshaft on the driver side exhaust pipe just pulling off of my driveway. I have since installed a 3-1/2" lift from BC Broncos and will still hit the exhaust under heavy articulation. I personally have never hit the oilpan with the differential, but see how it could happen if the flex was at it's most extreme point.
I think I will always have issues with the true dual exhaust. The one solution that I have seen for this is running a 2 into 1 system where the driver side pipe curves under the oil pan in front of the bellhousing.
drtodd
Eagle
I just installed a full width 44 HP under mine, with a 6 inch lift, no clearance issues whatsoever.
broncnaz
Broncos came with low pinion axles. I wouldnt bother with a low pinion full width really for what its worth not even sure why you would want to go full width with only a 2.5in lift. not to mention I dont believe ford had any low pinion full width d44's so any low pinion full width would have to come off another vehicle and would more than likely be a passenger side drop.
but anyhow bashing the oil pan is the main concern with the high pinion axle. in most cases you may never hit the pan but if you do happen to bottom out hard you will hit it with the lower lifts.
br0nc0xrapt0r
Loves pickles
It can be done but bump stops are going to be one of the key aspects of it. When I think about my "next" build I envision a low slung full width build.
yakelys69
yakelys69
Thanks for the input, I just picked up a hp full width off a 78 Bronco with disc brakes for a price I couldn't pass. Im going to order some cage arms or similar, cut the old buckets and play with moving forward while cycling it then decide on the sl. Then they tires, arb and gears.
br0nc0xrapt0r
Loves pickles
Duffs has new coil buckets for running full width and west coast broncos run a lot of full width setups, they are a good source to talk to. Also if you opt for west coast arms you can just go pick em up yourself in yucca and drop off your old ones for the core charge.
yakelys69
yakelys69
Those Duff coil buckets look great, Should make that part a bit simpler.
Dusty
My wife's Bronco, Coco, is on full width axles. It was basically a WCB conversion, as we did it back when I was partners with Jon at WCB. Up front it has a 78/79 HP D44 (cast wedges) and we used the coil bucket extension pieces I designed when I was there. I'm not sure if he still produces them for sale but I would bet they still at least do them as one-offs for their builds in the shop.
Anyhow, to address the OP's concerns. Coco has a 2.5" spring lift with a high pinion D44and WCB +12" radius arms. I don't even run bumpstops. The pumpkin has "clearanced" the oil pan, but I pulled it off and verified the pump pickup was OK so I just put it back on and run it that way. The driveshaft yoke gets into the driver side exhaust pipe just a little, near where it joins up with the WH shorties on the driver side. Those are the only two problems I've had.
yakelys69
yakelys69
Dusty thanks so much for posting that, glad I didn't buy gears yet. COCO Looks awesome. Originally I was thinking 35's with 4:56 I'm sure 37's are pushing the setup (89 FI 5.0, NV3550, 78 dana 44 & 80's 9" both to be ARB's) but if I do step up to 37's what's the recommended gearing 4:86?
Also what backspacing and tire width are you running on COCO? I saw some old post from "uncle ray" that are interesting about moving the axle forward and buckets up.
I think im still a member so after I get my axle blasted (any recommendations in North San Diego County? '), talk with WCB, and get some arms in my garage i will start a build thread, however slow it may be.
broncnaz
With 37in tires you would need about 5.13 gears to be able to use the OD effectively might get away with 4.88's. but with 4.56's speeds below 65 would require constant shifting. If you were running a 351 you might get away with 4.56's but the 302 wont like them so much.
br0nc0xrapt0r
Loves pickles
I run 37"s with 4.88 and a NP435, it's great but I agree with your OD you'll want to use 5.13 to not be hunting for gears. I think you could manage with 4.88 but really your better off with the 5.13. Also I'd invest in some WH silverback flares to avoid friendly chats with the CHP. Oh and I run +6 arms from WCB "don't know if you remembered that" and they are awesome, like Dusty though you would be best with +12 arms and some really good shocks to combat body roll. I noticed the body roll a lot when I first made the swap but now it's not even in the back of my mind as I drive. U was able to push my axle 1 inch forward without changing anything, so with new coil buckets it should be a snap.
