Was just looking at something the other day, but don't have the link right now. At Del City Wire maybe? Not sure, but it was basically one of those old fuse-taps designed to give you an additional blade connector at one end of a round glass fuse.
It's got the typical 1/4" wide flat blade at one end, but a nice curved section that is designed to go around the end of a fuse.
Not sure the exact thickness of it would be, but likely if one is not enough to tighten things up, two might do it.
I will say though, that by the time your fuse clamps are loose, the deterioration in general is pretty severe. If it was simply bent out of shape at one point, that's not a real issue and could be fixed by the curved adapter mentioned above. But if the looseness is due to excessive rust on the backside of the fuse panel, or by some previous overheating, then even tightening this up might be just a temporary fix.
Have you had the fuse panel out, or had your eyes on the backside of the panel at least, to make sure it's not seriously rusted out already?
Good luck.
