- Jun 19, 2014
- 4,121
Soo I’ve noticed a small leak under the green 70 bronco. It looks like really thin oil dripping from the rear main seal area. Further inspection it’s oil and gas mixed which is NOT GOOD! Reading up on this I found a few causes, bad fuel pump (just replaced it and this leak was happening before this so it could’ve been the old pump) and badly tuned carb. The car was taken off and cleaned out due to bad gas. I’m not sure if my dad adjusted the jets properly after reinstalling it. Any other areas of concern? I changed out the plugs as the other ones were laden with soot and heavy build up of carbon. I’m also def changing the oil immediately
