bannind
- Mar 24, 2005
- 612
1967 289 - stock fuel system.
Or at least I believe the fuel tank is stock. The fuel tank has a filler hose and another orifice to the right of the filler opening to it that shoots up to the cap. I believe this is the filler vent. I do not have any vents or ports to the left of the filler opening - is this normal? Newer vented gas cap.
Short story long - any time I fill up with gas, I always make sure I do it before driving around for the day so I don't end up parking the bronco with a full to the brim tank. Any time I fill up with gas and immediately park it the gas fumes are horrible. I assume that is due to fuel expansion and such. Came home last night, 1/2 full tank and parked in the garage as normal. Woke up this AM and the entire house smells like gas station. Out in the garage, the strongest smell of gas is at the carb. When I remove the gas cap, there is a large pressure release and usual hiss sound.
Am I building up pressure in the fuel system and is it running up and going through the carb to try and release the pressure? I do not have a charcoal canister or the evap/separator bottle either. I have no problem stopping by the junkyard to pick up 2 donors. but I don't know if I could make them work without the added vents on the gas tank. I do not feel comfortable doing any work on the tank adding ports, so if it comes down to it, I am just going to buy a new one if needed. I would really love to be able to park in the garage, but until I resolve the gas smell - the bronco will be outside in the winter weather.
Thoughts/suggestions?
