Should be able to find a compatible one (if not exactly correct, at least usable) from any late seventies to late eighties car or truck. There were probably only a few part numbers of the vertical plastic tanks that were introduced during the '76 model year for the Bronco. Already on the cars and full-size trucks I think, we didn't get them until '76.
Someone should post a pic of one soon I would think. There are lots of pics around the forum, including some of mine! But I'll see if I can find them on this jumbled computer I'm using right now.
But if you've seen one, you've seen them all. In fact, they're still available new from the local auto parts stores, Summit and Jegs, and the like.
The junkyard is normally a bit better sometimes though, as it's easier to find the "mushroom" caps that were used to keep debris out of the one large port left open to atmosphere. Usually the new ones don't come with, and they seem hard to find based on the normal descriptions. Someone here has part numbers too I'm sure. I've seen them posted up before.
