Oakland Bronco
Before my Bronco burned up, the Alt gauge would constantly "bounce" while driving. +30/-30/+30/-30...constantly moving and really fast.
I now have a new Centech harness. With the exception of the engine block, heads, and steering box, everything in the engine bay has been replaced with new parts. The old stock gauge cluster was replaced with a different, refurbished stock gauge cluster......AND......the Alt gauge bounces just like it used to.
Interestingly, the left-turn signal indicator didn't work on the old gauge cluster, and isn't working on the new cluster.
Stock steering column. Column wiring issue maybe? Thoughts/suggestions?
I should add that, in the past, there were a couple of times when I engaged the turn signal, and the radio cut out. Also, all of the aftermarket gauges and knobs that a PO added were removed and no new aftermarket gauges/knobs have been installed.
