High Beam Gauge Cluster Wiring
msommer001
Stock 1977 Bronco Ranger.
The high beam indicator in my gauge cluster is on when the low beams are in and off when the high beams are on. Seems like some wiring is back wards.
Any recommendations to correct?
WILDHORSES
USA
How is the dimmer switch wired? Just a thought, you might have the high/low wires reversed. Are the dimmer wires in a plug or individual connectors?
Jim
msommer001
msommer001
That was my first thought. They are wired to a plug and the plug connects to the switch. I can trace the wires and see. Might just be able to switch them at the plug.
Oldtimer
Jr. Member with Sr. moments
Sunnyvale, CA
Stock wire harness all the way to headlights, or has a relay headlight harness been added?
The heavy duty headlight harness I bought years ago had bad instructions.
It connected the red & green wires to the wrong wires on the Ford harness, causing low & high beams to be backwards.
msommer001
msommer001
Flipping the wires did not change anything. Not sure how the light at the gauge cluster is wired in…
jamesroney
Fremont, CA
The light at the gage cluster is tied to circuit #12 in the harness. That is the green with black wires. It is always the green and black wires, and the wire that runs to the indicator bulb is also green with black. Green with Black is high beam.
If your low beams are illuminated when the green with black circuit is energized, there is something wrong with the wiring at the headlight. You say that your Bronco is "Stock 77 Ranger" If the low beams are on when the green /black is hot...then it isn't stock anymore.
If the low beams come on when the red-blk wire are hot, and the dash light is also on, something goofy has happened.
START at the headlight bulb. Put the dimmer switch in low beam. CONFIRM which circuit is active. Go to here https://seabiscuit68.tripod.com/images/75-77_combined_v1.gif and you can see the circuit.
msommer001
msommer001
Grounds are good.
I did some testing today and something got changed under the dash somewhere as both headlights function the same and the low beam is tied to the green with black stripe. High beam is tied to red. I traced back to under the dash and I am not sure I want to get too far into it with all these old wires and connector.
Might just have to wait until I need a new wire harness.
Thanks again for the information and recommendations, truly helpful!
