Gear swap ratio?
rustbucket
I have a 351w, C4 and 4.11's turning 33's, and it seems like a good combo for me. 3.50's were too short, though they were okay with 30-31" tires.
garberz
Bronco Influencer
Conejo Valley, Ca.
I would just leave the gears alone, do the transfercase low gear set, or for a bit more money, get the Atlas 2spd. 4.3:1 transfer case. Having gear swaps done is going to to be a big chunk of change. If your happy with the way it drives around town, and cruises on the freeway, then just change your low range.
matt w
matt w
..Yep-Sir..That will be what I will do!..Tis the answer for the need I perceive!;)
broncnaz
Ya know what I am thinking of doing is a TRANSFER case gear reduction swap! That way I get that low end/tourqe on the trail and still have the highway cruiseing ability...that is why I ask about the cam!
Is 266H the kind of cam/numbers? or is it a style!;D
...I knoe not a thing about choosing and swapping cams for my engine & what that would involve!%)
Lokking for advice on this idea/concept;D
Its the grind number. actually I got it backwards its H 266-2 here's a link to the specs. its pretty close to the edlebrock performer specs. http://www.cranecams.com/product/cart.php?m=product_detail&p=24068
It pulls pretty good in my setup.
Swapping a cam is not really all that hard but it does take quite a bit of work in a bronco you either have to pull the engine or pull the grill off. But it makes a lot of differance in the engines powerband and in most cases you will probably gain some HP or at least gain it where you need it.
