BroncoManSam
- Jul 2, 2020
- 60
Hey everyone,
I'm in the process of choosing a new transmission, transfer case, lockers, and differential gearing for my '73 Bronco project and I have a general idea of what I want, but I'm looking for a second opinion (or two) about this tentative set up and my plan so far. 95% of the time, I'll be using the Bronco offroad, and that is what I'm building it for:
-Engine: Rebuilt 302, or stroked to 347 to put out *about* 300hp
-Transmission: NP435 4 speed
-Transfer Case: Atlas II Twin-stick
-Underdrive Unit: BlackBox-i (has a 2.72:1 low range, but also has the ability to multiply against existing transfer case low range offering 4 total low range options.): http://www.northwestfab.com/NWF-BlackBox-Underdrive_c_7.html
-Diff: 4.56 gears with ARB Air lockers front and rear
-Tires: 35x12.5x15r Goodyear Wranglers
I used this website: http://www.grimmjeeper.com/gears.html
to calculate my final drive and gear ratios with the setup above, and if I'm reading this correctly, my lowest gear ratio (transfer case low, underdrive low, 1st gear) would be 356.80:1 (I think?), which is insanely low, but I'm ok with that, as long as it's at least still drive-able at relative highway speeds (55-65 mph). Does this seem like a good set up for offroad use? Thanks in advance.
