Howard, correct me if I'm wrong but you are wanting hoses for the Explorer, reverse rotation serpentine dress, correct?
I have kind of an oddball radiator as the inlet and outlet size isn't typical so I had to use flex hoses...
from tech right up, see below. Hope it helps.
Stock Bronco Radiator. There are a couple of ways to go for both the upper and lower hoses. On the lower hose, to use the stock radiator, you can make a crossover tube like the one outlined in the
www.AZbronco.org website, or purchase one from BC Broncos (Fig. 9C). This will allow you to use the stock part number Bronco radiator hoses. They are mounted backwards and do require some trimming but they do work quite well.
With the 351W block a little trimming of the rubber connector hoses is necessary to get the upper hose to work. For the top hose, many people recommend using an early model GTO radiator hose, but some have trouble getting that to work properly. Another option for the upper hose is a Mr Gasket Flex Radiator Hose Kit from Summit (MRG-11012BL), although it is expensive (around $100 at this writing).
