EagertoLearn
I am going to give away the inline 6 cyl engine in the 1968 Bronco with the bad frame. It will come with the 3 spd transmission and transfer case. I had it started and it ran very well. It will need the water pump changed but I have a new one in the box for you. You will need to pick this up. I will have it pulled out of the frame tomorrow and will leave it hooked up to the cherry picker. You will be able to back right under and away you will go. The engine is in Ohio. PM me and we can make arrangements. I don't want to send a good engine to the scrap yard but would like to get the frame gone.
