crutch
- Jul 3, 2015
- 249
I've been chipping away at projects on my first bronco resto and I've come to the point where I have to replace the clutch on my original 3 speed manual. Given that I have to drop the transmission and transfer case I started thinking about a possible upgrade on the transmission. Been researching all the threads and leaning towards AX15 or NV3550 given my driving habits (mostly city and highway).
I have a stock 302 which I will likely try and rebuild in a year or so with performance parts or possibly go with a 347 stroker.
I've read a number of the threads about engine, gear ratios, RPM's, tire sizes and if the system isn't designed to work together you get no value out of the OD. I'm very new to all of this so was looking for any advice on whether I should possibly do the trannsmission upgrade now or is it pointless unless I re-gear (which I want to avoid). Should I just do the clutch replace now and then maybe think about it once I do something with the motor down the road? My 3 speed isn't very smooth so this is part of why I was thinking about upgrading now.
Appreciate any recommendations.
Stock 302
3 speed manual
D20 transfer case
3.5 gears
33" tires
Stock 302
3 speed manual
D20 transfer case
3.5 gears
33" tires
