nickmyron
I just bought a 71 Bronco that is in (for the most part) great shape. 84K original miles, 2nd owner, garaged its enitre life. But it does need some attention. I am going to get it painted (its got original paint now), but am giong to do the bodywork myself.
The only rust it has is on the floor pans and its nothing major (I think, i have definatly seen a lot worse). I am going to repair this first.
Heres the pics:
Drivers side (toward firewall):
*The PO put rust treatment paint over the rust, then put sheet metal over the top (There is also a piece of sheetmetal on the bottom that I havent taken that off yet). There is also some rust on the drivers kick pannel that you can kinda see in this pic, it only goes about 1-2" high however.
Driver side (where gas valve is):
Same spot but pic from the bottom:
Passenger side:
Same spot but pic from bottom:
I dont think that it would be worth replacing the entire floor pans, but if I just cut out the rust and make patch panels, weld them in and grind them smooth. It may be a little bit harder for the drivers side kick panel so I am not sure what to do about that.
What do you guys think? Just use a couple patch panels?
BTW-After fixing the floors, its heading straight for the Line-X shop to get bedliner in the tub!
Thanks,
Nick~
nickmyron@hotmail.com
Heres the pics:
Passenger side:
Thanks,
Nick~
