highrlr
Ok, I finnaly bought and engine for the EB project. Its an 5.0 HO out of an '88 mustang, i was a little disapointed though I thought '88s were mass air so I thought I could score the harness and computer also but it was speed density so I just got the complete engine with injectors(yellow ones if I remember correctly), upper and lower intake, and all of the sensors that are on the engine. This is not hard to convert a speed density engine to mass air right? what will I need to get, I am assuming the mass air computer, harness(probably get a new one made), mass air sensor, anythiing else? Oh and are all the sensors and such on the engine the same as an mass air?
The next question I had is I am going to rebuild this engine but will not be ready to put it in the bronco till next spring sometime, would you guys recomend not rebuilding it till im ready to drop it in or is there any negative side affects to rebuilding an engine and then leaving it sit for a few months? Also what is you guy's take on aluminum heads on a truck, yea or ney? I have been told to use CL77 bearings, double row timing chain, heard good things about erson cams, but what kinda pistons are good? How about rings? should I use the stock conecting rods?
Sorry about the long winded post but this is my first engine build up and its a fairly large investmint so I wanna get it right the first time, so any tips on building the engine, good parts, good places to deal with is greatly appreciated!
