andy, I checked the harness on my 73 and the Green/red wire comes out of the wiring harness about an 1.5 in. from the firewall grommet on the passengers side along with the yellow and orange leads which all three hook to the regulator. The grn/bl wire is the middle wire in the hook-up between the yellow and orange. This connector is made up of the 1/4 in. "quick connect" type terminals and the wires can pull out of them when one pulls the connector off the reg. The individual terminals can also be removed from the connector to fix or replace. There is a small tab in the terminal which keep it from backing out and can be depressed to remove the terminal.
Ruel
