Grill letters pdf install template
RedBank
All of the old links I find to the pdf templates for installing or drilling the holes for the grill letters no longer work. Does anyone have the .pdf to share?
Sent from my SM-G975U using Tapatalk
Bronco4x4
I used those recently (printed a while ago). I marked the areas to drill with the templates then held up the new grill letters afterwards. I did adjust the drill marks a little to fit better.
R
RedBank
I just opened it. You can’t?
Hank
I can open the link to the post but when trying to open the pdf inside that post I get an Adobe msg that the file cannot be opened because it is corrupt or damaged.
hankjr
here are screen grabs of two of the pages from that post
Hope this helps you out. when i did mine, i did it by eye FWIW
Hank
R
RedBank
I can see the pictures. I am looking for the pdf that I can print off that will be to scale.
Tosh
Germany
I am about to install my grill letters as well and thought I create a pdf template for everyone to use. You can print it out. There is a line with dimensions for reference, as it needs to be printed with 100% size. Please check the fit before use, don't know if all grill letters are the exact same size. Hope this helps.
  • ford grill letter.dxf
R
RedBank
These aren't what I was looking for but I can make them work. Thanks guys.
The template I was looking for had all the letters on a page laid out horizontal to scale. You could print out the page and hold the page up to the grill and mark all the drill holes. If page was level then all the letters would be level.
Again, thanks!!
