Any thoughts on the Flo-Tek 203-505 (1.94/1.54, 58cc) heads? smaller chambers to bump CR a bit, smaller valves to eliminate piston/valve clearance issues, under $1K for a pair.
The 302 race engines I built for our team had iron heads with 1.94/1.60 valves and 0.610" lift solid-lifter cam. I had to flycut additional clearance in to the top of Diamond race pistons. FWIW.....I always clay the pistons to check.
The FloTek is probably most suited for your requirements. The GT40X is the closest to the iron GT40, but still higher cost and less power compared to the FloTek. The Ford heads are great, but bang for the buck, FloTek is probably the only sub $1K aluminum head option for stock piston.
