Thank you guys for the info on the damper/balancer. Its ordered and will be here tomorrow. So maybe if Im lucky ill have all that crap back on the engine.
The Edelbrock manifold arrived, so I thought Ill get some work done. Got it mounted. Man that thing is too clean for my enginebay. I felt bad for putting in the dark bolts. But then again it will get dirty anyway. It went on well and all looks good. So im thinking of working ahead even more thinking that all fitment issues are worked out. The timing chain cover can go on but the thermostat housing still has issues. I followed all instructions by BC Broncos and even got the manifold they said will work 100% with the frontrunner kit. Mind you that the thermostat housing was supplied by BCB also. I just dont want to deal with the crap anymore so I sent the cover to a machinist to modify the alternator bracket.
The whole reason for going with the kit is to avoid issues such as this. It costs a lot and with all the modifications I have had to do I could have just gone to a pick and pull yard. I really dont understand. The manifold issue I get but everything else should not have happened at all.
Either way. The cover will come back tomorrow and I will continue then. Here are some pics of the manifold mounted.
One question I do have is about the timing chain itself. Is this double chain setup standard on Broncos? Thats very beefy for a stock setup I would think.
I was looking around the back and noticed a whole bunch of crap. two smaller pipes run toward the back what seems to be going to the trans. I have to get uder the truck later to see where they go. In pictures I did not notice others having this. Are they breathers of some kind? I would like to get rid of that whole contraption and if they are breathers just put the small K&N breathers on there.
Thanks again guys for all the insight to this craziness we call our hobby!!;D
