Half cab sliding rear window
doghows72
I figured I'd better put this in its own thread so here is the process I used to make my rear window for my Bronco Designs Half Cab.
I started with a slider from an 86 Ford Ranger. It has the same arch to the top as the half cab does. The ranger window is a lot taller but narrower in width.
So first things first was to disassemble the window. Pretty straight forward to do, a couple screws and pull out all the rubber seals.
I cut it down to get the top to bottom fit and clamped it all up.
doghows72
doghows72
Next was to find some aluminum channel to make the rest of the frame fit the bronco opening.
doghows72
doghows72
Glass ordered, and cost me about $200 for tempered tinted glass. While I waited for that I powder coated the frame work.
Glass came in some now for final fit and assembly.
doghows72
doghows72
Fits great, so take it apart and and install all the gaskets and glue in some of the key pieces.
Final test fit.
doghows72
doghows72
Installed sealed and ready in about an hour after the sealer has set up.
I'm pretty pleased with myself. My buddies were a great help with this as well.
Final product!
doghows72
doghows72
Thanks for the kind words. Now to get back on that fiberglass tonneau cover.
FRANKO289
Bronco enthusiast
fantastic work on the rear window !!! ... I am curious about the 3rd brake light !!
doghows72
doghows72
That will be installed today or tomorrow. It's basically a 30 light LED. It can be hooked up with turn signal and brake or just all brake.
I'll post up when it's done.
FRANKO289
Bronco enthusiast
oh ok ... I was thinking down the line like the late 90 FSB have. 3rd brake in the middle and clear left and right that illuminate the bed when you open the door or via separate switch on the dash !?
