Hand brake?
Hinmaton
I like to rock crawl my ‘74. And with a standard it sometimes wants for a third leg, which is where an emergency brake can be of assistance. But having it foot operated defeats this. I love a hand brake for these occasions, but how to do it in an EB?
Well I’m here to tell you it’s quite simple actually.
I bought a used TJ hand brake, cut it in and it works a treat.
Bolts right up to the original cables in the original position and has a spade connection for a dash light (going to wire it into my dash brake light).
bronconut73
Some fellers use two hand brakes.
One for each rear wheel.
Allows for super sharp turns and helps a Tru Trac or an open diff throw power over to the other wheel.
Your install looks damn near stock.
Good work Bud.
Hinmaton
Hinmaton
Looks great and thanks for the excellent pictures. Did you have to cut the actual handle or just the floor opening?
Just the floor and the original e brake cable pivot bracket, the hand brake drops exactly where that was. I eyeballed my cut, wish I had of made a template...
I now just need to find some type of boot to cover my over-cut. If cut tight, the TJ hand brake assembly has a nice drop down plastic under-cover with flanges that would otherwise hide any notice of the install.
Hinmaton
Hinmaton
Hinmaton
Good work Bud.
Honestly, I'm half tempted to see if can install the e-brake assembly into my front drums and tie it all to one handle- then I could use it for brake biasing on a front Tru Trac.
ObscureMachine
Seatbelt Orifice Officer
World Headquarters
I love this idea, but I have a big Tuffy Console in between the seats so I can't put it there. I saw someone put a lokar one on the left side of the Driver's seat, but that's a short handle, and probably wouldn't fit with aftermarket seats. One person put one right in front of what would have been the tank switching valve, so you pulled it up toward the passenger side. Not sure I like that. I need to think this through.
NGABronco
Always Learning
N. GA now South Carolina
I have the same set (Jeep handle) in my "Stretch" rig, like said it crowds out the certer console idea.
In my crawler, it has a small bicycle brake lever on the shifter (NP435) attached to the carb, gives you the third leg when crawling!!;D;D;D
Good luck!!!;D;D;D
blubuckaroo
Grease Monkey
Ridgefield WA
My brother installed a similar brake handle from a fork lift in the same position as the original pedal parking brake mechanism.
It was a good option for a handle when you have a center console.
