At no point did even suggest using a 4180 in an EB. I would point out that those who own a mid '80s Bronco with a 5.8 HO that was originally equipped with a 4180 and need to comply with emission laws can make small mods that will bring their 351 up to acceptable performance levels. The 4180 is 600cfm and a torque oriented 351 works better with a 450-550cfm carb. I've just re-cored my radiator with the high density type,and am trying to install baffles or air dams to keep heated air from reentering the radiator. I also like the idea of using a 7 or 8" fan to move cool air into the engine compartment after the engine is shut off. A thermostatic switch sounds perfect. Where do you mount it? We all know the temp gauge pegs it self after engine shut down and that's the most likely time for the engine to boil over. The small fans not mounted on oil coolers are a lot less $ . I wonder if pushing cool air in or pulling hot air out would be best.
