Hard Starting Issue - Need Help/Advice
mavsfan21
Conroe, TX
I have been having issues starting (long cranking times) with the bronco lately. It is the stock motorcraft 2 barrel. My first thought was that the fuel was draining or dissipating from the fuel bowl... but I just went and checked and the fuel bowl is full after sitting and the accelerator pump is working as I can see two streams. After cranking for a while it will eventually start and run at the fast idle setting, but if I hit the gas pedal too soon to drop the idle down the truck will almost immediately die.
Don't know the ignition has anything to do with this problem but I have the following ignition components:
- petronix ignitor kit
- larger distributor cap with male terminals
- ford motorsports plug wires
- autolite plugs opened up to .044
Any feedback would be greatly appreciated.
Chuck
phred
Earth
Has the timing been checked or changed? Do you give it any gas before you try to start? Both my broncos like at least 3 pedals before a cold start and 1 pedal for a warm start.
mavsfan21
mavsfan21
Conroe, TX
Check timing recently and it was still at 10 degrees BTDC
My starting process requires constant pumping of the gas... it used to be like you stated two pumps on cold start and it would fire right up on fast idle.
mavsfan21
mavsfan21
Conroe, TX
When I pump the gas before starting the choke plate closes like it should and after running for a while it slowly opens up. This would lead me to believe that the auto choke is working properly.
70_Steve
Old Guy
Kinda still sounds like it's running lean when it's cold. How are the idle mixture screws set when it's warm?
