Hi, when the engine is warmed up the choke should be fully open and held open by spring pressure. Which carb do you have. My Bronco came with a manual choke. When you start a warm engine you should hold the gas pedal @ 1/2 way down. Don't pump the pedal, just open the throttle. Good luck
