Harmonic balancer and flex plate question
Karl's 68
green bay
Can a harmonic balancer and flex plate from a 70's 302 be bolted up to an '86 302 and have it balanced correctly. I am trying to avoid purchasing a 50 oz flex plate when I already have a used balancer and flex plate. Thanks, Karl
Bolt up, yes
Balanced correctly, no
They changed balance of both the damper and the flexplate in about '81~'82 on the 302.
Karl's 68
Karl's 68
green bay
Even by changing both of them it still won't work? If I do need to get a new 50 oz flexplate how many teeth are required to work with the Bronco starter? Is the tooth count stamped on the ring gear or flexplate itself? I see there are 157 or 164 tooth available. May have to look in the local junkyard. Thanks-Karl
brewchief
The crank is what's differant, the balancer and flexplate must match the crank, not just each other. Flexplates are pretty cheap, I wouldn't mess around with used.
Brewchief;D
gravy
Parsippany
I just went thru this- Ford Motorsport also has the 50oz 164 tooth in the 11.5 pattern for 30 bucks. I had to change my converter to the bigger one since I had the 10.5. I couldnt find a 50oz flexplate with the smaller pattern. The 50oz is a must as mentioned before- Its needed to balance the motor properly.
