Yellow75
Stumped on this one. Have the harness installed and everything works perfectly. Lights, dash lights, dimmer switch etc.. Volt Gauge works, but new tach, oil, temp, Fuel are stone dead.
I can see a dead ivr causing issues with the oil/temp/fuel but the tach is dead also. While I do have lights on the tach. Which tells me I have a ground. It's the Classic Bronco tach from Wild horses. Tach is a DUI distributor with the one wire tach connection.
Last night I ran a ground from a good spot on the chassis and tried connecting it to the back of the cluster to see if it wasn't having an issue with the powder coat to no avail. I did use the grounding studs in the dash that BC provided and cleaned them of powdercoat so it should be getting a good ground..
