has anybody ever used this set up ?
JDJ
Dothan
I am in the middle of installing my efi. Anybody ever used this type of fuel rail and fuel line down to the axle? I got this fuel rail from a pick and pull. Forgot to take my spring lock quick disconnect tool and had to take the line from the rail to the frame too.
I think the rail was off an explorer. Not 100% sure because they were laying loose under the hood of an explorer
JDJ
JDJ
Dothan
What about the lines that go from the fuel rail down to the frame?
Pedestrian
Bronco Missionary
Those are the Explorer rails. They make for a very clean install.
The lines you have attached to them don't go down the firewall, they actually attach to clips along the top of the valve cover haeading toward the front of the motor.
If you are careful, you can cut the crimp off of the stainless braided portion and remove it from the quick disconnect. This will yeild a barbed 5/16" fitting that you can clamp high pressure rubber line to.
