My temperature is running as high as 105 degrees on the highway.
Newly rebuilt 302 engine, 4 core radiator, 7 blade fan and shroud. Although; it has been in the high 90’s here, I would feel better if I could get it down to at least the 190s.
Has anyone used “Water Wetter”? Before I try a bottle, I thought I would run it past to see if anyone knows about it or possible problems associated with it’s use.
TIA Lou
http://www.redlineoil.com/products_coolant.asp?subCategoryID=4
Their advertisement claim:
WaterWetter®
WaterWetter® is a unique wetting agent for cooling systems which reduces coolant temperatures by as much as 30ºF. This liquid product can be used to provide rust and corrosion protection in plain water for racing engines, which provides much better heat transfer properties than glycol-based antifreeze. Or it can be added to new or used antifreeze to improve the heat transfer of ethylene and propylene glycol systems. Designed for modern aluminum, cast iron, copper, brass and bronze systems. Compatible with all antifreezes, including the latest long-life variations.
TIA Lou
WaterWetter®
