clinem03
- Sep 9, 2017
- 401
Alright, have to revive this thread as I’m having a hell of a time getting her in 1st or R again. I spent a few hours today adjusting the linkage after setting a pin in neutral at the column…my steering column doesn’t have the welded eye hole as mentioned, but it has a white u shaped piece between the two column shifting arms which appears to be how I center it with a pin (see photos). After setting it it’s hit or miss if it will “pull back” on the shift arm on the column inside the cab to get it in 1st or R. It just stays locked (if you will) in the 2nd and 3rd part of the H pattern. I did micro adjustments, macro adjustments and always the same result. It will go in 1st or R sometimes, then it gets stuck in the 2nd/3rd column. I had the trans out a few months back for a clutch and flywheel replacement, at the time they flushed and refilled all the fluids. It shifted pretty well post work and it wasn’t until I got it back from the detail shop from its ceramic coat that I’ve been having issues (not blaming them, if they messed it up it wasn’t on purpose, I only share the detail as “something” could have changed at that point). I also noticed some oil dripping down the shift arms on the trans at the point where they enter the trans (see photos). It always had a bit of oil there but nearly as bad as it shows in the pic but I kind of chock that up to the fact that I was messing with it for hours and fighting getting it into gear. What could it be? Any thoughts? Is it my adjustments or do I have bigger issues with the oil leak at the trans that could prevent me from getting her into 1st and R when shifting it the cab. FWIW I can move the shift arms into their positions easily at the trans…my big issue is getting the shift arm on the column in the cab to pull back into the 1st/R column of the H pattern.
