If you want to use the column switch instead of the dash switch you can just unplug the dash switch and run the flasher power to the column white-red wire.
'70 Column Connections
Blue=12v from turn flasher to turn switch, circuit #44
white-blue=right front turn and indicator lamp, circuit #2
orange-blue=right rear brake and turn lamp, circuit #5
green-white=left front turn and indicator lamp, circuit #3
green-orange=left rear brake and turn lamp, circuit #9
red-black=12v brake switch to turn signal switch, circuit #810
yellow=12v headlight switch to horn switch, circuit #460
blue-yellow=horn switch to horn, circuit #482
'70 Hazard Connections
red-white=12v from fuse panel to hazard flasher, circuit #383
white-red=12v from hazard flasher to hazard switch, circuit #385
white-blue=hazard flasher to body connector (ties to RF turn light terminal), circuit #2A
green-white=hazard flasher to body connector (ties to LF turn light terminal), circuit #3A
red-black=hazard flasher to column connector (ties to brake switch output), circuit #810A
'74-'77 Column Connections
green=right rear brake and turn lamp, circuit #282
yellow-black=left rear brake and turn lamp, circuit #283
blue-yellow=12v horn relay to horn switch, circuit #1
blue-red=12v from headlight switch to PRNDL light, #19
