Header Bolts Against Header Tubes
PNW
If you've never had headers leak, you weren't using them in the '60s, '70s, '80s or '90s before companies started making them with 3/8" flanges.. :)
Header flanges aren't anything like a rod nut to rod tightening..
steel to steel.
Header fastening is totally different with a thick paper or soft "lead" gasket..
blubuckaroo
Grease Monkey
Ridgefield WA
The problemis it's easy to fabricate cheap headers.
You should have bought Hooker headers.
The quality has always been excellent.
I've been using Hooker headers for a long time. They've always been a perfect fit.
68ford
ARP sells 3/8 header bolts with 5/16 6 point head.
You would be amazed at how much easier that one size smaller makes things.
PNW
Guess my pockets and 90% of my friends pockets for our first 30 yrs of building cars just couldn't afford Hookers...
... and I went to Summit, not to Hookers site but they didnt have any headers that would fit my rig or any of my budds due to suspension issues. My JBA's always fit but larger primaries for 450+ cubes is needed
73azbronco
Put hooker headers on my dads 460 pickup in 1978, never retightened them and he sold it 30 years later still rumbling away no leaks.
blubuckaroo
Grease Monkey
Ridgefield WA
Anytime a header is unevenly tightened or overtightened, you run the risk of distorting the flange. Once it's distorted, the seal surface is pretty much ruined.
That goes for both the cylinder head flange and collector flange.
Getting a torque wrench into some of those bolts is impossible. Using a crows foot socket helps, but you need to consider the length of the crows foot when setting the torque.
PNW
Light gauge flanges back in the day, 3/16' thick gaskets and you have a recipe for leaks for sure.
I bought the first set of Duff's headers with the 3/8" flange back 30 plus years ago... leaked and backed put every 2 hrs of driving. Stage 8 fasteners with same gasket for 20 yrs and never touched them again.
My JBA's have been on 11 yrs and not a leak w/o Stage 8
